additif a l'huile
Tu vas regarder ton gros livre, as tu une belt ou une chaîne? Vu l'année je dirai une chaîne, regarde a quels klms ils recommandent de la changer. Certaines oui d'autres non.
Tu te débrouilles tu un peu en anglais? Regarde le texte tout est bien expliqué et les symptomes.
Timing Belt & Chain Description
In your motor, timing is everything. That’s why your timing chain and/or timing belt are so vital to the operation of your entire vehicle. You see, without a properly installed and adjusted timing chain or timing belt, the valves on your engine don’t open and close at the appropriate times. A sloppy timing chain can result in poor running, valve clatter, and loss of power, while a broken timing belt can cause your engine to stop running or, on an interference application, cause your valves to crash into your pistons. If that sounds expensive to you, you’re right. If a broken timing belt can cause so much damage, why doesn’t everyone use a timing chain? For all its advantages, a timing chain is noisier, less efficient, and more expensive than a timing belt. These timing belt / timing chain comparisons are particularly relevant on the overhead cam engines that are so common these days. Since an OHC timing chain would be so long, a timing belt actually has less lash and stretch resulting in better camshaft timing and improved efficiency. So don’t think that, just because your manufacturer specified a timing belt for your favorite ride, they’re looking forward to the day they can supply you with a remanufactured engine. In many cases, a timing belt makes more sense than a timing chain. While a timing chain may last the life of an engine, a timing belt has specific requirements for replacement intervals. Check your owner’s manual for timing belt replacement mileage and follow those requirements to the T. If you have a timing chain instead of a timing belt, signs that your timing chain may need replacement include loss of power and noise from the timing cover at the front of your engine. Unlike the timing belt crowd, you probably won’t destroy your engine by running with a worn out timing chain. You might get run over by a semi on the interstate, however, trying to accelerate with that clapped out engine and its stretched timing chain!
La procédure normale du "tune-up" complet comprend cette vérification de la "timing chain".
http://www.mecamotors.com/
j'ai regarder dans mon livre et dans la liste d'entretien a faire, la timing chain est pas indiquer..... j'ai fouiller rapidement et j'ai pas vu grand place ou il pourais en parler, je vais reverifier sa demain pour etre plus sure. sa semble plus etre poudreux mais vraiment pas gros, en passant mon doigt dessus, c'est juste pour dire que je reste avec un peu de noir... :)
Puis.... Bonne saison ! :D
Une chaîne distributive qui est usée cause une baisse notable de la puissance du moteur, des difficultés au démarrage et des arrêts fréquents du moteur, sans raison évidente. Les bougies montrent des signes de mauvais fonctionnement.
Tant que les bougies restent belles et que le tensionneur reste efficace, la chaîne est bonne.
Avec un bon entretien et une conduite normale, les chaînes modernes peuvent faire facilement au-delà des 150 000kms, voire même 200 000kms. Par contre, avec une conduite généralement très agressive et surtout, avec un entretien minimal, une chaîne de distribution peut être trop usée dès les 50 000kms.
C'est la loi de la relativité, quoi.
la timing gear, y en parle pas... a moin que sa soit le camshaft ou quelque choses du genre... si c'est sa, sa semble terriblement compliquer a aller verifier, mais y dise qui a un tendeur qui est supposer s'occuper de sa, du moin, c'est se que j'ai compris :?
pour se qui est de la syncronisation des carburateur, sa semble vraiment pas compliquer 8)
je vais peut etre meme le faire a la prochaine journée assez chaude, ayant deja demonter tout mon fearing et ma tank pour les repeinturer, sa ferais sa de moin dans les jambes :) oui je sasi que sa ferais vraiment du bien de le faire, seul hic, je suis pas encore assez bon en mechanique et j,ai pas l'argent au cas ou je fais une gaffe.... pis j'ai pas le gout de la perdre pour des jours pendant que je fais sa :P
1. démarrage du moteur et montée en température normale de marche
2. réglage des carbus au son, en utilisant les vis de réglages des tubulures
3. essai routier.
Si ce n'est pas correct, retour à la case 2.
Un ami mien utilisait une longue tige métallique, fixé bien droite, en l'air, à un boulon du cadre, à la façon d'une antenne. Ça lui faisait un solide indicateur de vibrations. Sa technique à lui était de diminuer au minimum les vibrations du moteur causées par la synchro des carbus.
L'un dans l'autre, on arivait tout deux au même résultat.
une clutch humide......elle va etre scrap dans le
temps de le dire.(huile moteur,transmission et clutch)
sauf dans les harley-davidson.
clutch humide mais l'huile ne se melange pas avec
celle du moteur.(primary)
je met du produit prolab dans mon shovel
depuis l'ete passe.
il a completement change.....start mieux,tourne
mieux et cote performance....wow.
moin de friction,donc plus froid (on s'entend)
ca ne se donne pas car il est formule pour les
moteurs diesel,essense industriels.
:D :D
http://www.vmoa.net/
http://www.sportster.org/
si je laisse ma moto se rechauffer, meme si y fait assez frais, je peut faire l'ajustement :)
vmax, c'est tu dans ton harley que tu mets se melange ou dans ton v-max ?
mais si sa enleve la friction, la clutch va avoir de la misere si je comprend bien... non?
Merci :wink:
jamais dans mon vmax
:D :D
édité par Chichille8 pour améliorer la compréhension.
Dis...ton lien ou tu as pu aller downloader ton livre d'entretien pour ta moto, tu l'aurais pas encore? Parce que je me suis acheté ma ptite Yamaha Virago 1100cc 1986 l'été passé....alors les livres d'entretien de cette époque, les gars ne les ont plus. J'aimerais bien me downloader ça!
Ta photo, t'étais devant le PWD ou une autre école? :wink:
sur le site des sceptiques, que j'aime bien:
http://skepdic.com/slick50.html
De plus ça empêche le gommage etc... alors voici le produit en question
marvel mystery oil
Je sais y aura toujours des septiques mais je vous le dit ça la vraiment fait une différence.
a gazon,ne contient pas de teflon ou ptfe......
a voir:
http://www.prolab-technologies.com/cont ... roduit=187
http://www.prolab-technologies.com/multimedia.htm
le video en dit long........
:D :D
Sinon, les grands manufacturiers d'huile modifieraient leurs produits, c'est un peu comme les économiseurs d'essence, je n'y croit pas trop.
Je crois qu'il y a des huiles meilleures que d'autres... çà économisera autant le moteur que sa consommation... tant qu'aux additifs, je passe mon tour, j'ai appris que des "mécaniciens en canette" çà vaut ZÉRO !
pour ce qui est des kossins pour présumément économiser de l'esence... méchant attrappes nigauds !!! Si quelqu'un veut vraiment sauver, il a juste à relentir, accélérer moins fort et faire plus d'autoroute... C'est ainsi que la moto sera la moins gourmande.
j'ai reussi a retrouver l'addresse apres 20 minute de recherche....
le lien pour le mien ne fonctionne plus, c'est quand meme assez vieux mais tout y est, tu n'a qu'a faire une recherche dans la page (ctrl + f)
et aussi, juste pour te dire, sa peut etre long a downloader, sa ma pris environ 3 jours a l'avoir :?
http://www.bikechatforums.com/viewtopic.php?t=41567
Devant le PWD a la journée du loup 2007, photo prise par Poppy955i :)
au plaisir de se renconrtrer cette ete (si elle fini par arriver :lol: )
Ah c'est la beauté de notre société,les fameux débat sur l'huile moteur ou les additifs. Mais moi aussi j'étais sceptique toutefois j'étais fatigué d'entendre mon moteur au ralenti faire ces cliquetis, pas que c'était très bruyant mais moi je l'ai entendais. J'avais même fait faire un ajustement moteur sans résultat.Jusqu'au jour ou j'ai découvert cette huile ou plutôt cette additif qui ce mélange a l'essence dans le cas des moto. Mais chacun est libre dis croire ou non, peut être que tout est dans ma tête ;) , c'est peut être juste un placébo :shock:
La journée du loup, je ne connais pas ça non plus, c'est quoi?
Merci pour les tuyaux, je me rend voir ton lien sur les manuels d'entretien.
drette a ca que jai pensé avec 94 000km, moi sur mon zx6 1994, a 65 000km jai changer la cam chain (ou timing chain). la piece coute env 75$ mais cest une méchante job a faire (Faire!). un mécano expérimenté va l'entendre claquer, moi javais juste des doutes.
autres choses a faire : tune up des carbus, chagement des bougies, brakes avant arriere, spocket avant arriere, chaine et tire d'en avant. env 750$ que ca ma couté. Dailleurs ce bike la est a vendre pour les interessés. 2500$.
manque un tire en arrive par contre (200$ posé) bon pour rouler au moins 2 saisons sans mettre une cenne dessus ;) sauf les tires bien sur;) MP pour ceux qui veulent un bon bike full fairing avec 100hp sous le capot et qui veulent payer le meme prix pour les plaques qu'un custom :) le bike est rendu a 67 000km si je me rappel ben.
ps: je veux pas faire de hijacking ici, fait changer ta cam chain au plus vite ;)
