Ajustement des valves
A quel inter val doit -on ajustées les valves sur un v-star 1100 2008é Merci a l'avance de vos réponses.
Yamaha V-Star 950 2009
Pierre Chartrand (C) 2017
I have a 09 model and the manual recommends valve adjustments after 600 miles, then every 4000 miles after that.
I think they changed it to every 16000 miles after break in period on the later models 2010-2012.
I have a '09 950, and the owner's manual for my bike says the same thing about valve clearance at 600 miles, and every 4,000 after that. But the service manual for my bike says to do it every 16,000 miles.
It's a bit of an involved job that I can't see doing two or three times a year. I'm just going with every 16,000 miles. My first adjustment is coming up in under 1,000, so I should be doing that one in another couple weeks.
steph
avait besoin d'un minime ajustement, le mécano ma dit que cela aurais pus attendre
encore un autre changement d'huile soit 6000 km. Donc qui croire? De plus j'ai demandé a l'ancienne proprio les valves n'avaient jamais étées ajustées elle ne savaient qu'il fallait
faire cet entretien.
